Mounting bracket for Power Commander
Old 10-15-2010 | 01:43 PM
Kev_England's Avatar
Kev_England
Default Mounting bracket for Power Commander
Hi Guys,
I have the pc5. Seems to be working fine, however, I really dont like the idea of it just sitting on top of the wiring harness under the seat and flopping away at will. I'm thinking of fabbing up a simple mounting bracket and screw it into the top of the frame with machine screws. Then I could glue a piece of rubber to the bottom of the pc5 and mount it to the bracket with plastic ties. Hopefully this could help isolate vibrations from the pc5 unit. Anyone else done something similar, or am I being paranoid?
Cheers!
Old 10-15-2010 | 01:49 PM
nevil's Avatar
nevil
You are probably paranoid, but that's not a bad idea. I don't know how much room you have under the seat that it's flopping around, it can't hurt to do that. When I had a Fuel Pak I used some thin high density foam to cushion it from bumps and vibration.
Old 10-15-2010 | 02:05 PM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by Kev_England
Hi Guys,
Cheers!
Wait a minute....you have THAT much room under your seat that something can actually flop around? I call shenanigans. LMAO.
Old 10-15-2010 | 05:11 PM
daBreeze's Avatar
daBreeze
mine was so friggen tight to get in there that there is noooo way there is enough room for it to move at all
run1fsr
General Topics/Tech Tips
12-02-2017 09:12 AM
run1fsr
11-21-2017 09:51 PM
No U Glider
2014-2023 Touring Models
14
12-12-2016 05:17 PM
hedgehorn
05-24-2010 09:46 PM
dh2683
10-26-2008 06:46 PM
Quick Reply: Mounting bracket for Power Commander
