Bike just died
Bike just died
I have an 03 Lowrider that has a carb. I'm going down the highway and all of a sudden the bike just dies. I pull onto the shoulder and coast, switch to reserve even though there's only 70 miles on the tank. It takes a minute or two and she starts up. I go another few miles and she dies again. This time she won't start. So I'm stuck on the side of the road for about 20 minutes checking fluid levels, battery connections, plug wires just about anything I can think of. All of a sudden she starts up so I decide to cancel my ride and get her home. She died out one more time coming home but I finally get her in the garage. Now I am stumped. I haven't done any work to her recently and I ride pretty much every day to work. Any suggestions on where to start would be appreciated.
Check the fuel tank vent. If you have dual tanks, it's the right side when sitting in the saddle.
If it's not working right, you'll end up with a vacuum on the tanks and no fuel flow until it bleeds down.
Also check the ignition coil. I've had them overheat and short out only to work again after cooling down. Encapsulated or not, they do go bad as they are sitting out there in the open most often.
Could also be the ignition timing trigger (right side of crankcase) overheating or wet from condensation and shorting out.
Just a couple things to look at. Good luck.
Start with the basics. Check for spark. Pull the fuel line from the carb and see if you are getting a good flow of gas. Check the charging system, battery, alternator. and voltage regulator. When she died on you did you have a headlight, directionals and horn? Did it sputter like you were running out of gas? If everything went dead it could very well be electrical. Check the ground on the battery. You need to go through and check and eliminate each system.
X2 on the battery cables. If they're tight up top, check the lower points as well. If those are good, check inside the protective layer on the cables, water could have been making its way in there over the years and corrosion can hide and strike you down without ever seeing it.
I just replaced the battery and checked it on the side of the road. I replacedthe fuse but it doesn't look like anythings wrong with it, but I did make it home. When she died I still had lights and turn signals. I just replaced the fuel filter before my trip to Sturgis. Is there any way to test the ignition coil?
The fuel shut off is also vacuum operated, there is a vacuum hose going from the shut off to the carb. Check the hose , if it is good the valve in the shut off will let some fuel flow but not enough thus causing it to starve. I went to a non vacuum shut off and plugged the hose. Problem solved. I was stumped by this for awhile myself because when you check for fuel flow at least in my case I got some and decided to change the shut off anyway and it fixed it.
Received 4,799 Likes
So far all I have found is some white powder around the fuse and the fuse had some corrosion on it. I replaced the fuse and cleaned up the white powder and sprayed some avoinics cleaner in there. Rode to work with no problems but I just don"t have a warm fuzzy feeling that the problem is fixed. I guess I'll just have to go for a long ride and see what happens. Being straned on the side of the highway sucked.
