HeadLight Mods (time for a thread)
Old 10-08-2010, 05:04 PM
flipman's Avatar
flipman
flipman is offline
Originally Posted by CDW
Flipman, love that front fender. Is there a matching one on the back?
nope , stock one with a piece cut off . maybe i make one but i think it does not look so good on the rear ??
  #62
Old 10-08-2010, 05:49 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I added a brass visor and some high/low indicator lights, since I lost mine when I went with the Springer. All these way cooler lights than mine in this thread has caused me to reevaluate my puny light. I need to hit ebay this week and come up with something nicer. I like some of the ones I have seen in this thread thus far quite a bit more than what I'm running.
  #63
Old 10-09-2010, 06:55 AM
FenceSC's Avatar
FenceSC
FenceSC is offline
Originally Posted by DeathProof72
Got any pics? Actually wanted that myself, but the Black one with the chrome grill has been on back order for the longest time. I think actually a dual mont with two rapide lights would be the sickest look ever (and way expensive!).
Its on order. Won't install till the weather gets too cold to ride. I plan on pulling the front to have the triple tree and lowers powder coated.
  #64
Old 10-12-2010, 09:37 PM
BeavisRules's Avatar
BeavisRules
BeavisRules is offline
Here is a stupid question for the guys that put a fatboy headlight in their streetbobs.
Did you have to splice any wires or is it just a straight swap? My headlight is rattling and it might be a good time to look at the Fatboy light.
  #65
Old 10-12-2010, 10:05 PM
blacknsilver's Avatar
blacknsilver
blacknsilver is offline
Mine was straight forward but had 2 extra wires for auxillry lights and I just capped them off. Got mine off ebay was aftermarket $52.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
  #66
Old 10-12-2010, 10:19 PM
DeathProof72's Avatar
DeathProof72
DeathProof72 is offline
Very easy actually, the plug on the end of the wires (inside the headlight) opens and using a jeweler's screwdriver or similar device (I used a pump needle used o inflate a basketball, only because the end was blunt ad wouldn't accidently cut the wires) you can press the 2 retaining tabs to pull the wires out. Then the rubber plug can be twisted through the hole (some harder than others), I actually cut mine with a razor, then used a strip of electrical tape on it once I put it back in. Then reverse to reassemble, no splicing and the easiest way t get at the wires. I ave my FB light out for recoating, so will be putting it bak on next week. If you want, I can post pics..
  #67
Old 10-12-2010, 11:29 PM
mercury01's Avatar
mercury01
mercury01 is offline
Just a note on the HID conversion - fwiw. Make sure you specify the small ballast unit. The stock automotive one is quite a bit larger and may not fit. SHARPHID offers good product an service Can be found with a simple search.
  #68
Old 10-13-2010, 01:16 AM
onfloat's Avatar
onfloat
onfloat is offline
Originally Posted by ratt196635
Here is mine
I Like it!!
  #69
Old 10-13-2010, 03:45 PM
Blackhawk's Avatar
Blackhawk
Blackhawk is offline
Here's my Wide Glide with an HD Bullet Headlamp:
  #70
Old 10-14-2010, 11:42 AM
parts eeter's Avatar
parts eeter
parts eeter is offline
I am looking for a cheap 4 or 4.5 incher headlight. can somebody drop a link for a single dominator or any generic small headlight?
Quick Reply: HeadLight Mods (time for a thread)
