Which 1450 (88) or 1584 (96) cant make up my mind ..
Old 09-28-2010, 12:05 PM
santerre1974's Avatar
santerre1974
santerre1974 is offline
Default Which 1450 (88) or 1584 (96) cant make up my mind ..
I cant make up my mind over 1450 (88) 5 speed or 1584 (96) 6 speed is there a diff and is it worth it ? please help anyone
Old 09-28-2010, 12:17 PM
CountryPunk's Avatar
CountryPunk
CountryPunk is offline
Pretty obvious difference. One has a bigger motor and extra highway gear. Bigger motor=more power=faster. Extra gear=lower highway RPM's. Both bikes are plenty fast out of the box, but if the price is pretty close between the two, go for the 96.
Old 09-28-2010, 12:22 PM
dpriest's Avatar
dpriest
dpriest is offline
cant really say it any better than that
Old 09-28-2010, 12:30 PM
VirtualNorm's Avatar
VirtualNorm
VirtualNorm is offline
a bigger question would be EFI or carbs IMO. I went from a 96 EFI to an 88 that has a carb. EFI is the best option unless you like to "Tinker" a lot..
Old 09-28-2010, 12:31 PM
thetroll's Avatar
thetroll
thetroll is offline
^ what they said... go big or go home...
Old 09-28-2010, 12:41 PM
traveler's Avatar
traveler
traveler is offline
I prefer 88.
Shorter stroke....like to rev better.
That said 88's, at least 2005 and older need gear driven cam conversion or '06+ cam chain setups.
6th gear is nice, but not necessary....5 speeds work fine. Hell, there are guys still riding 4 speed bikes all across the country.
MINT 2005 Dyna Superglides can be picked up for a song. Change out the cam setup, and RIDE.
2006 was an oddball year. The engine was a new design, and there are some one year only parts in them.
I recommend 2004-2005 dyna with gear driven cams (and upgrade to TIMKEN cam bearings)and chromoly adjustable pushrods personally.
~Joe
Old 09-28-2010, 12:48 PM
LozoB's Avatar
LozoB
LozoB is offline
I'm with the Punk.
Old 09-28-2010, 01:28 PM
ynots's Avatar
ynots
ynots is offline
buy the 96 and be done with it, the 6 speed is very sweet
Old 09-28-2010, 02:57 PM
santerre1974
its a 2006 flhx 1450 any good ?
Old 09-28-2010, 02:58 PM
santerre1974
but is it worth it that much ?
Quick Reply: Which 1450 (88) or 1584 (96) cant make up my mind ..
