Replacing Shifter Shaft
I have an 07 Street Bob with mid controls. My shift lever keeps loosening up and it looks like the splines on the shifter shaft are stripped.
Has anyone replaced their shifter shaft? Is it complicated?
The indy quoted me 4 hours. Does this sound about right?
If anyone could give me an idea the steps involved with this repair it would be greatly appreciated.
Thanks.
Thanks.
Any mods I should consider while everything is apart?
No real mods necessary but I suggest you look at the condition of the stator, chain tensioner, and consider replacing the inner primary bearing (if it needs it) while you have it apart.
Something to think about... The gaskets and sealing bolts can usually withstand reuse if the bike hasnt been apart before. If they already have one reuse on them, you'll have to get new ones and they aint cheap. Rolling the dice for a third trip around amounts to a case of russian roulette
I would see if you can find a sleeve/bushing that would fit over the end of the shaft and give enough grip to hold the shift lever before taking the entire primary apart. Or you can drill a hole through the end of the shaft and another through the shift lever and run a cap screw through with loctite on it. Or tack weld the lever on the shaft it until you do the repair during downtime. .
splitting_lanes
05-27-2008 08:52 AM
