Lift points on Dyna SB
anyone have pictures or can tell me where the jack point are on the frame. There are two points under the mid control mounts the hang about an inch down, the look like thay would be where the stand should go, only the kick stand is inline with them and doesn't allow you to put the lift there. I would imaging that the welded walls on the frame around the oill pan I would imaging is where the rear lift point is. I just need to know where the front part of the lift goes.
this is the lift that I have. It's a Bluepoint, sold by snap-on
You need to get the dyna blocks for that lift to work, the lifts are too close together. Or you can cut it apart and make it work, that what I did. SC-Longhair did a write up for it here - https://www.hdforums.com/forum/dyna-...ification.html
Yours looks the same as the sears so it should work for you, cheaper than buying the blocks
