Oil burner?
Received 4,811 Likes
Some 05's were known to have the wrong valve guide seals installed and that repair(which involved pulling heads) the MOCO covered. The plugs usually tell the story and if yours are tan and dry, have to look else where. Pull your derby cover with the bike upright and see if the oil is at the bottom of the clutch. If oil pours out, the crank seal behind the stator may be leaking into the primary case. If your okay with the primary level then you're just may have to pull your exhuast and look for oil residue.
FatBoy Jay
04-25-2008 07:44 PM
