Have you lowered your Dyna?
Old 09-21-2010, 07:47 AM
maryland blackout's Avatar
maryland blackout
maryland blackout is offline
Default Have you lowered your Dyna?
So I want to lower my superglide in the rear. What are some ways to do it and did it affect the steering/riding? Is changing the shocks the easiest way and is that an easy switch? Pics are always appreciated.
Old 09-21-2010, 07:57 AM
dFREDb's Avatar
dFREDb
dFREDb is offline
I dropped mine with 11.5 inch Progressive 440's. The effective drop at the bottom of the rear fender was about 2.5 inches. This affected the trail slightly, making the steering a little "loose" at very low speeds. I dropped the front 2 inches with the Progressive drop in lowering springs and it handles great. I am very satisfied with the results.
Old 09-21-2010, 07:59 AM
skip3406's Avatar
skip3406
skip3406 is offline
I lowered mine and does not affect the steering/riding. I just adjusted my handlebars to compinsate for the change in angle.
Old 09-21-2010, 08:02 AM
hdgzr's Avatar
hdgzr
hdgzr is offline
Received 2,750 Likes on 798 Posts
I tried the lowering blocks for a few months; ending up taking them out...just didn't like the way the bike felt.
I've used the shorter shocks and springs on my previous dyna and was happy with the look and ride. I'll probably go that route again in the near future.
I have a set of blocks I'll sell ya' if interested. My bike's an '09 Street Bob...
Old 09-21-2010, 08:13 AM
maryland blackout
how do lowering blocks work? And did you instal your own shocks/springs?
Old 09-21-2010, 08:23 AM
hdgzr's Avatar
hdgzr
hdgzr is offline
The lowering blocks just change the angle of your rear shocks...moves the bottom mounting point back...causing them to "lay down" a bit creating the lowering affect.
Yep, wrenched on the shocks and springs myself. About a one-beer job, unless you like to stand back and admire your work...then it's two or more!
Old 09-21-2010, 08:32 AM
maryland blackout
Gotcha. But you didnt like the way it rode? What felt different?
Old 09-21-2010, 08:33 AM
love4steel's Avatar
love4steel
love4steel is offline
I did mine EXACTLY the same as dFREDb.. except I switched to heavy screamin eagle fork oil when I did the front. love the results. lots of info if you search the forum
Old 09-21-2010, 08:35 AM
maryland blackout
sounds good. I'm hoping someone with an '02 superglide might have some input also.
Old 09-21-2010, 10:36 AM
hommes's Avatar
hommes
hommes is offline
Default dFredb
dFredb,
Are you sure the back fender dropped that far with those shocks? I read on here where guys were using 412 series 11 in. and only able to drop 3/4 in. Maybe it's because you dropped the front too?
Does your bike bottom out any? I don't want to drop the front, just the back...what kind of drop do you think I'll get. I have an '09 dyna. TIA.
Quick Reply: Have you lowered your Dyna?
