Question for Fatbob Owners
After reading the thread about the muffler bracket shearing the bolts that go into the transmission case, I went and checked mine out. Sure enough I am completely missing one of the bolts.
What I need to know is what kind of bolt belongs on the bottom of the stock exhaust muffle bracket? There are 2 at the top of the bracket right next to each other (looks like a bolt, then a stud with a nut on it) What was at the bottom of the bracket?
Is it the same exact bolt as either of the other 2 that are in the bracket? I have a set of V&H Big Shots on the way and I only need one of the stock bolts to mount the new bracket so I'm hoping my missing bolt is the same as one of the other two.
I'd appreciate any responses, thanks
The parts book shows a 'locknut, flange' (PN 7531) similar to the nut at the top of the bracket. This implies that there is a stud from the transmission casing at the bottom and top of the bracket. The nut is further described as a LOCKNUT, 5/16-18 X 9/32 X 1/2 flange.
When adding after market exhaust to a Fatbob you will often need to add the P-CLAMP used on all other Dynas to support the forward manifold. If the installation instructions ask for a P_Clamp you'll need:
PN 65975-99 Exhaust Bracket, front
PN 65440-06 Clamp, bracket upper
PN 65441-06 Clamp, bracket lower
PN 942 Screw(x3)
PN 5414 Bolt, carriage
PN 7601 Locknut
PN 942 Screw(x3)
PN 7601 Locknut
