Rear wheel removal 2007 FXDC
I reversed by axle, but it looks like the threaded end of the axle would hit my pipes if the suspension extended any further (bike is up on a jack and there is not enough room to stick a finger betweek axle and exhaust support bracket). Will the suspension extend any further than when its on a jack?
4. After reinstalling the front wheel and putting the front axle back in, you need to align the front axle by putting a 7/16" drill bit in the hole in the right side of the front axle, then lever the right fork leg against the 7/16" drill bit, and then tighten the piece of **** Axle Cap Screws to 10-14 foot pounds. (I used a large screwdriver between the right fork leg and the wheel hub to pull the fork leg against the 7/16" drill bit - it was easy.
RenaissanceMan
09-13-2008 08:39 PM
