Question Installing Rigid Mount Sideplates for Sissy Bar
Hi all. I embarked on installing a sissy bar setup with Rigid Mount Sideplates (Part# 52856-06) on my 2010 FXDC. Looks like a simple enough job but I ran into a snag 10 minutes in. I removed the torx screw securing the fender support cover to the fender. I then went on to remove the bolt securing the rear directional which has to be done from inside the fender (tire side). It was tough to get at while the bike is on the side stand but I was able to get it with a box wrench. Here is where I ran into the problem. The screw is so long you can't pull it out once unscrewed because the rear tire gets in the way. Is there a way around this or does the bike need to be on a jack so the tire drops far enough without the weight of the bike to get the bolt out?
Is there another way to get the tire out of the way. Outside of this obstacle it looks like 30 minute job. Any help is appreciated.
Lift up on the rear end.
You don't have to unbolt the shocks. If you can find some one to lift up on the rear fender for a few seconds you get enough clearance to push the bolt in. Been there and done it. Having it on a bike lift also helps. It takes a little upper body strength to do this. Had to send for my son.
Make sure you get the turn signal wires back in the little clips/guides on the inside of the fender. They could rub and cause you problems later if you don't.
Your right except for the problem with the bolts its a 45 minute max job, if you have the jack or someone to lift the rear end up.
Thanks for all the help guys. I am hoping to be able to do it just by taking the weight off the back tire like suggested. Unfortunately I don't have a bike lift/jack so I may just see if I can do it with a car scissor jack. I am hoping that jacking just a few inches while leaving the tire still touching the ground is enough; just like jacking a car. Like mentioned above 1/2" should be plenty to get the bolt out. Hoping not to have to remove lower shock bolt.
I'll report back when complete; probably not until tomorrow night since I plan on spending time riding this weekend rather then wrenching.
I knew I should have picked up the Harbor Freight lift when it was on sale last week.
Thanks a lot
