Trouble with install of HD highway peg mounting kit
Sounds like your installing the adjustable ones. I had some weld splatter in the bottom of the holes on mind and could not get it out. So i just cut 1/8 of an inch off of the allen bolt. It worked fine.
Put a nut on the allen bolt so you don't mess up the threads before cutting. I used a cut off wheel.
I broke a wrench and nearly my hand when it snapped and I hit the motor with my knuckle.
Don't worry about the 3-threads part, as long as the plates can sit flush on their mounting surface, w/o the setscrews lifting them. If they must go deeper, just run a tap through, first.
