modifying dyna super glide exhaust
Old 08-30-2010 | 04:54 PM
loufrang77's Avatar
loufrang77
Stage I
Default modifying dyna super glide exhaust
Does anyone have any tips on punching out the baffles on a super glide or a link that has somewhat detailed instructions?
I know that a lot of people on here say this is not a good idea, but it is it alright to do until I can gather enough money to get some aftermarket pipes?
Thanks in advance for the feedback.
*8151
Old 09-01-2010 | 02:22 AM
HemiOrange's Avatar
HemiOrange
*8151
I just removed the slip on mufflers, set them end-down on a piece of wood and punched a centered hole in the baffle plate with a "pencil tipped" sharpened piece of 1/2" round bar. Quick and easy. I got a little more sound from the pipes, but they would still pass the broom-stick up the exhaust test for legality.
Old 09-01-2010 | 09:54 AM
bikerlaw's Avatar
bikerlaw
Thats exactly what I did. Tool a 1 inch square bar stock. Unbolted the muffler, and ran the bar threw. Now before you go nuts and do this, I have seen people post that some newer bikes the baffles just unbolt and pull out. Since you didn't mention your year, all I can say is at least check first and see if they just unbolt and slide out before you drive the bar threw. This is how mine looked after I did my bafflectomy. The bike ran better and was noticeably louder. Not drag pipe loud by any means, but certainly more volume and tone.
Old 09-01-2010 | 10:07 AM
risdo's Avatar
risdo
I didn't punch mine out... I drilled them with a 5/8" hole saw.
I didn't keep them long, though. I didn't like the sound. Within a few months I had replaced them with the Supertrapps I still have now.
Old 09-01-2010 | 12:27 PM
HDDyna2006's Avatar
HDDyna2006
I ran a construction iron rebar thru the back of mufflers. make sure to use gloves.
10 DWG
07-13-2017 11:24 PM
woodie2892
02-06-2017 10:23 AM
DianneB
05-05-2015 11:26 PM
Hinson
10-31-2013 12:07 PM
sportster 883
01-02-2009 07:42 PM
