Removing Heat wrap...what to expect?
I am planning on removing the heat wrap that i have run on my thunderheader for the past 2k miles.
What is the best method to do this? Soak it in water or remove it dry.
What can I expect my pipes to look like? Will I need to have them recoated or painted with hi temp paint.
Thanks
Mat
Thanks
Mat
You can take it off wet or dry. Doesn't matter.
Be prepared though. Your pipes will be trashed. I bought a set of pipes from a guy who wrapped them. When I took it off they were pitted and the finish had some rust. No biggie though because I just cleaned em up and hit them with some black BBQ paint.
Thanks
Mat
Thanks
Mat
A better looking bike !
why are you removing? you should paint heatwrap after install with some DEI black paint. It keeps the wrap black. So if your just removing cause the wrap looks bad, you could just repaint the wrap and it will look good. Should you remove, the finish underneath will be fubar as stated. You can just remove the wrap dry.
Dyna346
07-30-2012 09:31 PM
