Just installed iso retro pegs and stirups Please Help
Appreciate the suggestion Joe only problem is these aren't Kury stirrups.
The day I had my bike tuned I lost the right side pad. I found it sitting up the street at the stop sign near the tuner's shop. Anyway, I used some grip glue on it and I swear it's never coming off. I should have proactively done the left but didn't. so...use the grip glue just as you would if you were installing grips and they won't fall out again.
Shhhh, don't tell anyone else on the forum but it was HONDA grip glue.
Well the Kurakyan break pedal and shifter look a bit longer than the harley ones on my bike now -may give them a try Kurakan also has a Brake Pedal Pad Extension
http://www.kuryakyn.com/index.cfm/go...D/91/IMID/3975
http://www.kuryakyn.com/index.cfm/go...ID/90/IMID/581
Almostinvincible119
08-02-2017 01:12 PM
