engine light
engine light
Hi guys, new Harley owner here so you will have to excuse my ignorance. I've got a 2003 wide glide with 3500 miles on it. The bike seems to run great. Today I noticed after it had been running for 30 to 40 minutes the engine light came on and then went off. Stopped the bike checked the oil all seemed good. Started it a bit later same thing after about 30 or 40 minutes running time the light comes on then off then on... Any idea what would cause this? Does that check engine light do more than just oil pressure? Thanks
Okay thanks guys, I'll try and find the link. I was worried something went wrong with the oil pump. Whatever code it is, it dosen't seem to affect it much, the bike seems to run great. This would definately be an engine issue correct? not something like a burnt flasher, or something similar? thanks
ya it is a code but it can be for anyting... here is a how to to make your life easier...
How to check diagnostic codes
https://www.hdforums.com/forum/dyna-glide-models/264270-check-engine-light.html
https://www.hdforums.com/m_2293229/tm.htm
https://www.hdforums.com/forum/dyna-glide-models/139328-identify-trouble-codes-and-clear-them.html
https://www.hdforums.com/forum/dyna-...06-2008-a.html
