do i have to pull engine to paint rockerboxes?
On topic - I second and third everyone who has suggested a service manual.
USMAMule
lol ok...
1. Remove tank
2. Remove 6 bolts holding rocker cover on.
The reason I say remove the tank and because when I did mine during my cam install to reuse the pushrods, I tried just lifting the rear of the tank but I couldn't lift it enough to gain the proper clearance. The tank would hit the trees when tilted up.
You may want to invest in a service manual for that project though.
You will need to replace the rocker cover gaskets.
[edit] Why is the site thinking the poster's name is a bad word. "j o r d a n". That's funny.
1. Remove tank
it's not flagging j*rdan as a curse, i'm sure it has something to do with MJ's brand and copyright nonsense and has some legal jargon that'll explain it all...
as for pulling the rockers...does anyone know if the OP is just looking to PC the tops? or if he wants to powder the complete rocker assembly?
the top rockers are just a few bolts and pull them off...
bottoms are a bit more involved.
To the OP, you have to take your rocker arms off, then the long small allen head bolts.
I just did my 883 on my 99 Sporty, and it was the first time I had ever been into the motor at all on mine.
Took my time, had no problems at all. I did read through the manual, but to be honest, it is a simple tear-down.
You already have the hard part, getting the top cover off of the rear cylinder. No clearance to play with there.
Good luck, you can handle it.
RD
