do i have to pull engine to paint rockerboxes?
Old 08-24-2010 | 06:57 AM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by ******ball33
someone should do a write up, or post a link to a previous write up on how to remove rocker boxes for powder, i love the look, it would be nice to do this winter
lol ok...
1. Remove tank
2. Remove 6 bolts holding rocker cover on.
The reason I say remove the tank and because when I did mine during my cam install to reuse the pushrods, I tried just lifting the rear of the tank but I couldn't lift it enough to gain the proper clearance. The tank would hit the trees when tilted up.
You may want to invest in a service manual for that project though.
You will need to replace the rocker cover gaskets.
[edit] Why is the site thinking the poster's name is a bad word. "j o r d a n". That's funny.
Old 08-24-2010 | 10:28 AM
JRK5892's Avatar
JRK5892
bit off topic but we have a set of rocker boxes in the shop that will fit your scoot, can powder them any color and they are ready to go!
Old 08-24-2010 | 10:39 PM
jordanball33's Avatar
jordanball33
top and bottom? if that is even correct terminology... i guess im trying to say everythign thats shiny above the top fin...
Old 08-24-2010 | 10:49 PM
SC-Longhair
LMAO...top and bottom is only correct when referring to gay dudes.
Rocker cover (top)
Rocker housing (bottom)
Old 08-24-2010 | 10:58 PM
jordanball33
Rocker cover (top)
yeah... what he said
Old 08-25-2010 | 09:15 AM
redrubicon2004's Avatar
redrubicon2004
Someone already did it. Just look in your service manual
Old 08-25-2010 | 09:19 AM
redrubicon2004
Once the top rocker cover is off, put the engine in gear and spin the back tire untill the cylinder you are working on is at TDC (Piston is all the way up and valves are closed all the way) both rocker arms will down on the pushrod end.....Then remove the rocker support bolts and remove the rocker support.....Then remove the bolts that hold down the lower rocker box....You are done....Easy job! Just make sure you are at TDC or you can bend a pushrod during assmebly.
Old 08-25-2010 | 01:13 PM
SC-Longhair
That's funny right there.
Seriously though, to get the rockers off, I had to remove my tank for bolt clearance. I did try raising the tank but it still made the job a bit cumbersome so I just removed it, and placed it safely out of the way.
Old 08-25-2010 | 02:07 PM
JRK5892's Avatar
JRK5892
yep i got the top and bottom bud
Old 08-25-2010 | 04:33 PM
toastman's Avatar
toastman
it's not flagging j*rdan as a curse, i'm sure it has something to do with MJ's brand and copyright nonsense and has some legal jargon that'll explain it all...
as for pulling the rockers...does anyone know if the OP is just looking to PC the tops? or if he wants to powder the complete rocker assembly?
the top rockers are just a few bolts and pull them off...
bottoms are a bit more involved.
Quick Reply: do i have to pull engine to paint rockerboxes?
