Hot weather stop and go....
So I am sitting in the parking lot called I-275 coming out of Tampa today in 96 degrees and 60 percent humidity (you West Coast guys think it is hot?). Got to thinking about the best way to ride in that situation when you can smell the heat coming off of your engine. When the traffic starts moving for a bit, should you let the revs build some to slosh some oil around or keep it low (not lugging of course).
Also, when the geek in the mini-van is glaring at me because he doesn't like the sound of my awesome pipes by his window (or maybe he is just glaring because his wife has his nuts locked in her dresser drawer and he wishes he had a bike with loud pipes) does it add to the heat too bad for me to keep blipping the throttle for his amusement?
I don't even like driving through this small @ss town i pass through every day. Two lanes avg speed 30mph or less. Fortunately i live in the country and i can avoid this route all together. When i do have to go through town cruising at 35 mph in 2nd gear raps the motor a bit about 3800 rpm but it likes it. Sportsters don't do putt putt well.
Received 4,838 Likes
I would lay off blipping the throttle if you are sitting for a while, you really don't need to add more heat. It's not like you have a fan attached to the motor.
Like others have said, find a way to get the air moving.
If it gets to the cylinder shut down, pull over and let her sit for a while.
Exactly...pretty basic stuff isn't it....I think even the geek in the minivan knows this!! Maybe he's glaring at the OP to make him rev more...so his bike overheats....
