running lean from the factory.
The 06 and 07 Dyna's are supposed to be running lean from the factory.
In theory if they would run richer the engine would run cooler and
it should also give longer engine life.
Has anyone considered putting a Fuelpak , download or other means
of making a totally stock 06 or 07 Dyna run richer?
I know, I know why would you want to bla, bla, bla, bla.
Lets just say someone does not want to add more sound and the stock AC
suits them fine. Would there be an advantage to doing it to a stock bike?
I have the 61005 Fuelpak, Big Sucker and V&H straight shots on mine and like it.
WillieC
RE: running lean from the factory.
Power Commander has a map listed for what appears to be a stock 06 Dyna.
The map number is m811-001 and says that it is for Stock exhaust ,stock air filter and o2 eliminators installed. Other than that I do not know anything about it. It may work like a charm or be totally unneeded.
Zyklon
Zyklon
Mine did the same thing stock, i had about 2,000 miles on it and checked the plugs and they were a little too white. Since then, i put on a pipes an AC and had it dyno tuned with a sert and it runs like a raped ape and the plugs are a perfect light brown.
