Lower you front fender on your fatbob?
well... i have a st bob wiht a fat bob front fender on it, the fender is slammed to the tire... here is how i did it
ext cord, ran that on the tire and taped it there... then layed the fender on the tire, went though the support holes and marked it, then ran a pilot hole, drilled it out... cut off the excess and put it on... looks much better hugging the tire, i also moved it back about 2 inches so it curves the tire more... if you use some tape on the painted area you are going to drill though you do not have to worry about paint chipping or scratching your fender up durring mock up... better safe then sorry
