Need A Switched Power Lead
Need to wire in a power cord for my new Garmin 1350T GPS unit. It will be mounted on the handlebars so I'd prefer a power wire up front somewhere. Has anyone found a readily accessible lead up front that I can tap into or would it be easier to find one back at the battery? Bike is a 2009 Dyna Low Rider.
There is a four wire deutsch plug under the seat. It is an accessory connector and should be the only four wire deutsch plug under the seat. The plug has a rubber connector cover and should not be hard to locate. Wire 1 = accessory; wire 2 = accessory; wire 3 = stop lights; wire 4 = ground. wires 1 & 2 are tied together into the customer accessory fuse. wire 3 is tied to the back light stoplight fuse and not to the costomer accessory fuse, although it is accessible in the same connector. hope this helps. the wires are also color coded -- color blind so can't help you there. If you decide to connect there, for one "keyed" accessory you only have to use either wire 1 or 2 and wire 4 for the ground. wire numbers are on the connector, albeit, very, very small and hard to see.
option
LC's connector is possibly a much better way to go, but I'll mention what I did to get my GPS hooked up.
Since I wanted a hookup for a battery tender anyway, I connected that directly to the battery (it comes w/ an in-line fuse). Plugged into that is a cigarette-lighter-style receptacle which my GPS plugs into. Between trips I just unplug it, as it is not switched. Was able to run the wires under the tank, tucked up and out of the way, by snaking a messenger-line in first.
Foodog--checked my service manual. CORRECTION: Wire 1, orange/red stripe = customer accessory; wire 2, red/yellow stripe = stop light; wire 3, orange/red stripe = customer accessory (tied to wire 1); wire 4, black = ground. It is a good idea to use this connector and avoid adding extra fuses at other locations. the customer accesssory fuse is the number 9 fuse in the electrical caddy. By using this connector, you avoid cutting and splicing your harness wires. hope this helps.
Need a bit more info. Finally got around to pulling the seat off and looking at the wires. I found what I presume is the Deutsch plug (it has a rubber plug covering the opening and there are 4 tiny pins down inside). Is there a female plug available for this connector that you can wire into or do you just cut off the plug and connect directly to the wires? All I have been able to find in my service manual is the location of the Deutsch plug. Don't want to wind up screwing something up by cutting wires ***** nilly.
1 Post
Ronald Odett (01-16-2020)
Merci !! Not sure about our local electronics store though. Went into Radio Shack the other day and asked for some dielectric grease. Guy stared at me for a minute and said "I don't know what that is".
