Any problems adapting it? If anyone is interested, I still have my stock FXDF exhaust in my garage.
Nope. The rear exhaust bracket is the same. You just have to get a difference size bolt. The Fat Bob and Wide Glide use a 5/16", 2" bolt to attach the upper muffler to the bracket. The other Dyna models use a 3/8", 1-1/4" bolt that actually threads into the bracket to secure the rear header clamp. The smaller bolt used on the FB/WG passes through the hole in the bracket and screws into the mount on the muffler body.
I just picked up a set of these for fifty bucks. Included every bolt etc. Even scored the bracket for the rear but it has to be slightly modded to work on my lowrider. I have another bracket I'm praying will work better. The bracket fits but the bolts need to be longer. I can make the bolts but am unsure if the allthread I have found will work. Mines going on an 07 lowride. I may have figured out a fix using two 3/4 steel spacers and a couple longer bolts.
