Gas light on at 105 miles?
If you were to get 40 MPG, you should be able to go 188 mi before your tank runs empty ....
I am averaging about 38+ MPG but my light doesn't come on until about 120-125 miles ....
So, what did your fuel mileage turn out to be ...? If you were riding hard ... heavy with the throttle and you were getting really poor fuel economy, it is possible it is just what it is ....
R/
'Chop
R/
'Chop
R/
'Chop
R/
'Chop
I did that today, and this is what happened. After leaving the station I hit into the throttle just a wee bit and saw gas seeping out onto the tank and all over my leg. So I have to say I won't be doing that again anytime to soon. I'll just get fuel a little more regularly.
Oh! Yes the cap was on tight, as I did double check it.
If I do that, the first sharp right hand turn, and I have a steady stream of gas running out of the tank.
About everyone I ride with including my self has the same issue, tank goes to LO light, fill it up and had a gallon left. The dealer say that harley says a gallon off is ok for them, so you just get where you know you have a gallon left when you hit the LO light. They can take the float out and bend it but will try to talk you out of it.
mileage
I dunno why I even pay attention to it. I never had a fuel gauge on any of my race bikes anyways. I would just check fuel capacity on said machine and push my mileage until the fillup said I got within my safe margin of fuel remaining according to gallons on fillup. From then on I would just set trip meter upon fillup and ride that many miles.
I think on my Streetbob I was trying to stay around the 120 mile mark, but I may start pushing that window farther. I just reprogrammed ECU and installed baffles so I should get some better mileage as well.
How many miles are you guys pushing the Street Bob fillups? Anyone run her dry?
