Gas light on at 105 miles?
I did that today, and this is what happened. After leaving the station I hit into the throttle just a wee bit and saw gas seeping out onto the tank and all over my leg. So I have to say I won't be doing that again anytime to soon. I'll just get fuel a little more regularly.
Oh! Yes the cap was on tight, as I did double check it.
Gas is often stored underground, where it is quite cool. Filling the bike's tank on a hot day when the engine is hot the gas will quickly warm up and expand. As pressure builds up in the tank something will give and the gas cap is the weakest link, even if it is screwed down as tight as it will go. Best not to fill up too near the neck in the first place!
That will happen if any of us does what stng_96 said.
If pressure is building up in your tank, I'd have a look at that system ....
I fill up pretty close to the top ... I pull the pump nozzle out and peer down into the tank to make sure it I can see the fuel level ....
Only fuel I've had on my tank is when I screwed up and douched the tank inadvertently ....
R/
'Chop
p.s. You can see the tube in the diagram below if you carefully examine part number 124 (Street Bob, Low Rider) ... the tube is adjacent to the fuel gauge sending unit ....
Mine's doing the same thing. I think it's just new and is getting funky gas mileage. Not gonna worry about it until I get some more miles on it.
