front axle spacers, don't look right???HELP
Old 07-30-2010 | 01:24 PM
Buggz's Avatar
Buggz
Default front axle spacers, don't look right???HELP
Put my new front tire on, put the thing back together as the Service manual said, but the right side spacer looks as if it has an 1/8 in space between it and the right fork???Does the notch on the spacer have to go a certin way, I used the drill bit in the axle hole and torqued everything to spec, it just doesn't look right....HELP !!Right side when sitting on the bike
Old 07-30-2010 | 02:13 PM
ghostrider69's Avatar
ghostrider69
Well, is the rotor lined up in the center of the caliper? Can you grab the spacer and spin it on the the axle, if not then I wouldn't worry about it.
Old 07-30-2010 | 02:20 PM
ratt196635's Avatar
ratt196635
the edge of the axle sticks out the fork on the right sidenext to the wheel a little bit the spacer is up butted up to that small amount as said above if you can not move the spacer it is fine
Old 07-31-2010 | 08:29 AM
8541hog's Avatar
8541hog
I have the same little space, it is meant to be there. If you suck the fork in to take up that space your forks will stick and ride like a rock, YES, I learned this the hard way.
Old 07-31-2010 | 08:50 AM
Buggz's Avatar
Buggz
Thank you all. I feel better now
Old 07-31-2010 | 09:44 PM
==ShaDoW=='s Avatar
==ShaDoW==
You need to ad image tags to your sig pic, its only showing as a link
Old 07-31-2010 | 10:16 PM
08fxdf43202's Avatar
08fxdf43202
I don't know what year Dyna you have, but looking at the 09 parts manual it shows the same spacer for each side for all models except the Fat Bob.
In other words... your two spacers should be the same size... unless you have a Fat Bob.
Old 10-07-2021 | 04:04 PM
twobanger1's Avatar
twobanger1
My spacers are not the same, one is 1/8 inch wider. Whats up with that?
2007 Electra glide
Old 10-08-2021 | 06:36 AM
John CC's Avatar
John CC
2007 Electra glide
Not sure I understand the question. Doesn't it simply mean they are not interchangeable left and right side?
Old 10-08-2021 | 08:00 AM
Dan89FLSTC's Avatar
Dan89FLSTC
2007 Electra glide
Did you think that all bikes have the same size spacers on both sides of the wheel?
Quick Reply: front axle spacers, don't look right???HELP
