'Lopes' ... and 'goat-ropes' ...
Photos of the crank position sensor below ....
kk6pg - you said it ....
Jayson/Vic - a little additional background ... I got my pipe reworked just after I got the oil filter changed ... I put the pipe on and then within about a minute of starting it up discovered the leak was coming from the CKP sensor ....
Well, after I got the CKP sensor replaced, it took me almost an hour to get it cleaned up ... there had been oil all over the bottom and front of the motor, trans, and primary, as well as the frame, etc ....
After I got done washing it, I was pretty wiped out from running around all day so took a little break ... I went out for a test ride and some dinner, but it didn't seem to be running as good as it had been the day before ... so, I decided to skip dinner and head back ....
So a few notes after riding it this evening ... it did not seem as responsive on the throttle ... rode it about 25 mi total with about 10 mi at highway speeds 70 - 80 mph range ....
I was looking pretty closely at the push-rod tubes to make sure they all had good seals and that no oil was leaking from them ... checked pretty close around the oil filter and CKP sensor several times ....
At one point shortly before turning back I thought I smelled burning oil, but I couldn't see any ... I wasn't sure if maybe there was some under the motor/trans or in a crevice somewhere that might not have gotten fully cleaned and was burning off ... no cloud of smoke ... but, I gotta admit I was a little nervous ....
It almost felt like the clutch was slipping when I accelerated ... but, I could tell that the clutch was fully engaging during most of the ride; so, I was pretty sure that wasn't it ....
I guess I will have to say at this point, I think it is still a work in progress ...
I have a couple of thoghts and issues I need to mull over and try to get to the bottom of ...
- I was contemplating reloading a new base map into the T-Max ... since I rode around for about a week with a broken-off pipe, I am thinking the auto-tune feature might have altered itself so that it is not optimized with the new pipe ... I just put it on late this morning and ran it for probably less than forty-five minutes and only started three times (the TMAT is programmed to adjust itself up to 5% each time it cycles) ... the other thing I think I'll do is contact Zippers to see if they recommend a different base map to begin with ....
- I had never heard of a CKP sensor failing like mine did ... seems like there must be a reason why it got so chewed up ... since all I did was just replace the sensor, whatever caused it to fail may repeat the process and chew up the new sensor ... I think I need to find out what could possibly have caused it ....
- The first 60+ miles after I finished the cam job (riding around with the old pipe) it was pretty impressive ... as/when I get back to that 'place' I am sure I will be able to report it was well worth it ...!
If anyone has any ideas about the CKP sensor, be sure to chime in ....
R/
'Chop
R/
'Chop
Well, didn't check the website for their hours, but assumed Zippers wouldn't be around on Sunday ... so, I checked the maps in the software (and for online updates to the map library) ... found one with a lot of overlap with my setup (the map was for a SE 203 cam) ....
Just got done installing the map a few minutes ago ... reinitialized my ECM and turned on the monitor feature and started it up ....
Much better ... I was not dressed to ride and it started to sprinkle a bit as I was uploading the map to the bike, so I let it idle until head temp warmed up to about 215 and idle speed fell into a nice range (around 944 - 972) ....
Weather looks like if I head South for a bit I'll ride out of rain ... think I'll do that and loop back West and around and come back on Jamestown - Scotland ferry maybe ....
More to follow ... stand by ....
'Chop
'Chop
