Oil Change Pan
have a oil catch pan from the parts store that fits under my uncles low rider just make sure you buy the pan thats not to high or just go to the dollar store and buy you a cake pan the rectangle cake pans are metal and will slide right under as well and a flat cookie sheet will slide under the front to catch all the **** that spills from the oil filter. Don't ask my wife how i know this as she will get mad agian.
Just put plenty of newspaper under the pan and the bike in case you're as sloppy and careless as me. It's one of the few things newspapers are good for anymore.
Follow the Service Manual instructions and go for it. Also make sure you replace the O-Ring on the drain plug. It's worth the 99 cents. While I had the drain pan under mine with the drain plug out, I stood the bike upright and rocked it a tiny bit. But I've been called ****-retentive before. If you're changing the primary and/or the tranny fluid as well, I think it's imperative to get the bike straight so all the fluid will drain out of those unseen places.
My next door neighbor is very good mechanically. Very good. But he's had his bike for 12 years and takes it to the dealer for fluid changes every time. Except for once. He over-filled it and he shied away from doing it again. Silly. He also made a hell of a mess. Got oil all over everything.
The trick is to use something under the oil filter so that oil doesn't go everywhere. You can buy the funnel from Harley for $20 US or you can fabricate one out of an old 2-liter plastic coke bottle or you can simply use a piece of thin cardboard folded up. One guy here used a throw-away cutting board protector type dealio. I know what it is, I just can't describe it. It's a thin, foldable and disposable cutting board to protect your cabinets when you decide to butcher a deer in your kitchen.
Whatever. Don't feel bad for not doing routine maintenance on your bike yourself. It's a big club. If you want to save the bread and KNOW it's done right -- Go for it. If money is no object to you, let the dealer handle it.
