FXD doesn't have much compression, rear cyl...
Old 07-27-2010 | 12:19 PM
SURFOR Chop's Avatar
SURFOR Chop
Looks to me like the valve is just too small ... you can see light all the way around it around the valve seat ... (and the other valve is too BIG) LOL!
Hmmmm ... looks like whoever reassembled the head switched the valves ... hahahaha ....
*** the flashlight is being shone in through the intake port ... that port should have the larger of the two valves ... but, since whoever reassembled the heads switched the valves (and didn't notice it) the valve is too small to reach the valve seat (and hence to seal the compression chamber) ... also notice the larger (intake) valve is in the other (exhaust) port ... therefore no compression ...
I'd like to hear that explanation, too ....
[Had to puzzle over the photos for a minute before it dawned on me ...]
R/
'Chop
Old 07-27-2010 | 12:24 PM
scottyd's Avatar
scottyd
THE F-in VALVES ARE SWITCHED!!!! Whos his builder? lol
Vern1's Avatar
Vern1
R/
'Chop
Greetings,
After reading your reply, I went back and looked at the pics - looks like they did switch the valves....probably read that on interwebs somewhere also....LOL!!!
Old 07-27-2010 | 12:26 PM
scottyd's Avatar
scottyd
Bet if they did both heads that way it'd run much better!! LMAO!
Old 07-27-2010 | 12:28 PM
ydontya's Avatar
ydontya
Is that backwards valves?
sniper77's Avatar
sniper77
Originally Posted by Cblast
What the heck would cause that?
Someone with tools.
Originally Posted by Grendel4
Heat. Just a guess, but I'd say the exhaust valve 'tuliped' from the heat.
Total guess from here.
Good guess, wrong but good guess.
Originally Posted by Vern1
Greetings,
Did the owner say: "It was running great but only got around 35 MPG and I read somewhere on the interwebs that if I dropped the main jet 7 sizes it would get better gas milage......"
Is that a crack between the valve seat and edge of head?
You could call it a crack, lol.
Did you take one of the spark plugs out or did the owner forget to put one in? No way you'd run a compression check with only one plug in the head, right?
Actually I took the spark plug out to run a comp check and didn't bother to put it back in. Note the one that's still there is new, I guess he thought it just needed new plugs, lol.
R/
'Chop
BWAHAHAHAHAHA!!! BUT, you nailed it!
The Exhaust valve is actually in the intake port and the intake valve is in the the exhaust port.
things that make you go mmmmmmmmm, rotflol!!!
Old 07-27-2010 | 12:30 PM
scottyd's Avatar
scottyd
Gives new meaning to the term Harley Knucklehead!!
Old 07-27-2010 | 01:35 PM
JohnAE's Avatar
JohnAE
You have got to be kidding! Switched the valves? If at first you don't succeed read the directions.
Old 07-27-2010 | 01:56 PM
RidemyEVO's Avatar
RidemyEVO
The best part is someone didn't take the time to even lap the valves in which would have given an indication something wasn't quite right.
Old 07-27-2010 | 01:57 PM
Grendel4's Avatar
Grendel4
Originally Posted by sniper77
Someone with tools.
Good. Lord.
The pic is in two dimensions, so it doesn't leap out at you. Plus, I wouldn't even ever, ever consider somebody being that dense.
I figured, leaving a spark plug out would have been about as stupid as humanly possible. I should have known better.
The outlook for the survival of the species isn't as good as I had once thought.
Quick Reply: FXD doesn't have much compression, rear cyl...
