Bike hesitating - Lost fuel pressure and How I tested it.
I was on a 140 mile run today and half way through I found the bike hesitating. Idling low, lots of popping on decel and heavy flat spot under full throttle acceleration. Made it home ok.
Bike starts and idles so I we have spark. My symptoms are classic lean conditions and fuel starvation, so I figure low fuel pressure. I don't have the H-D fuel pressure adapter so I used my MAC fuel pressure gauge.
I removed the quick disconnect at the tank, then slide the spring clamp that holds the fuel line to the quick disconnect and removed the fitting, installed my T-fitting between the quick disconnect and the fuel line, slide the spring clamp back and secured the T-fitting to the quick disconnect fitting and re-installed the fitting, connected my guage to the fitting. Turn on ignition switch to run and a whopping 30 psi and then bleeds down immediately, did this a couple times and purged the line of air. Started bike and fuel pressure reads 30 psi and after idling dropped to 28 psi. Spec is 55-62 psi = Not Good! Actually, I tested it several times and then it took a big fat crap, O fuel pressure and I can hear quite a bit of by passing in the tank so maybe I have the split pressure hose in the tank or a faulty regulator??? Guess I am lucky I made it home.
Here are some pics of how I hooked up my guage
Note; you could just run a plastic tee fitting with just a small amount of fuel hose, I just used what I had in front of me.
CB
