Rear turn signal plugs. .... Do they make em?
Old 09-25-2010 | 10:38 PM
Trippster's Avatar
Trippster
Heres what I did. Went to the local boat supply store and bought a couple of small cleats, about $3.00 bucks. Not very good pictures,but you get the idea.
Looks pretty good and fucntional too. Buy the way they are an 2007 wide glide.
Old 09-27-2010 | 02:49 PM
franticbilly's Avatar
franticbilly
Interesting! Not quite what I'm going for, but a great idea.
The oval caps p/n 68028-03 are for the light side, not the strut side. I think I'm going to cut some pieces from steel and weld them onto the strut covers, then just powder coat the finished product. I'll post pics as I progress.
Old 10-01-2010 | 05:12 PM
Bugger's Avatar
Bugger
Default Rear turn signal relocation kit
Here is what you need. http://cgi.ebay.com/ebaymotors/HARLE...item336139a8d5
Note the two oval pieces that when installed will cover up the holes.
Old 10-01-2010 | 05:23 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Recess cover (2) p/n 47531-06....
Old 10-01-2010 | 05:36 PM
Bugger's Avatar
Bugger
I find this:http://www.chicagoharley.com/shop/pr...ducts_id=31218 But need a picture of it to see if we are talking about the same thing.
Old 10-01-2010 | 06:49 PM
p51bombay's Avatar
p51bombay
I have bungie nuts holding it down but you can see the cover - could look better but at least its covered.
Attached Thumbnails Rear turn signal plugs. .... Do they make em?-pict0010.jpg
Old 10-01-2010 | 07:11 PM
Bugger's Avatar
Bugger
Default Bingo!
P51bombay, is this the HD part #47531-06? The oval cover-up piece?
Old 10-01-2010 | 07:23 PM
p51bombay's Avatar
p51bombay
Sure is
Old 10-01-2010 | 07:35 PM
Bugger's Avatar
Bugger
Jousley is currantly out of touch (moving to new residance) but thanks to you P51 and FXD 2003Rider I think his problem is solved and for just $6 bucks.
Old 10-01-2010 | 07:37 PM
Squirrel67's Avatar
Squirrel67
Old school hole plugs, rifle or pistol shell casings cut down, also makes good bolt head covers. Non auto cartridges work best. Oh and make sure they have been fired first.
Quick Reply: Rear turn signal plugs. .... Do they make em?
