Something about 8 degree injectors being bad? Need Help!
Hey I have an 06 street bob with 15K. I have noticed that the past few weeks the bike has been bucking and surging on me while riding it. During acceleration and cruising it will do this but not at idle. I remember reading something here that there was a recall for the 8 degree injectors to be swapped out for the 25 degree one's anyone with help or info please fill me in.
M-1185 1 of 2
SERVICE BULLETIN
M-1185 February 20, 2006
FUEL INJECTOR/CALIBRATION CHANGES FOR 2006 1450cc
BIG TWINS
Purpose
It has recently been determined that the 8
angle cone spray
fuel injectors used on 2006 1450cc Big Twins may cause cold
start and/or driveability problems on some motorcycles.
In the interest of promoting customer satisfaction, the 25
angle cone spray fuel injectors used on CVO 103 cu. in.
(1690cc) motors will be installed on all production Big Twins
beginning on or around February 13, 2006.
Additionally, Harley-Davidson will provide for the installation
of 25
angle cone spray fuel injectors on those motorcycles
where use of the 8
fuel injectors (part number 27625-06) is
determined to be directly responsible for cold start and/or
driveability problems. See REQUIRED DEALER ACTION.
NOTE
Due to changes in the manufacturing process, the part number
of the 25
angle cone spray fuel injector is changing from
27709-06 to 27709-06A. This fuel injector also will be
stamped with the words “25 DEG” for easy identification. See
Figure 1.
Motorcycles Affected
Only 2006 1450cc Big Twin model motorcycles that exhibit
cold start and/or driveability problems directly related to use
of 8
angle cone spray fuel injectors (including those subsequently
equipped with P&A Screamin’ Eagle 1450cc or
1550cc Performance Kits).
Required Dealer Action
1. Adhere to the flow chart in Figure 2 when handling customer
complaints regarding cold start and/or driveability
problems on affected motorcycles.
2. If the flow chart indicates that the fuel injectors are the
source of the problem, check the part numbers stamped
on the fuel injectors. While standing on the left side of
the motorcycle, the part number on the rear fuel injector
can be easily read with the aid of a flashlight.
3. If required, remove both 8
following the procedure in the applicable 2006 Service
Manual. Install 25
fuel injectors, either part number
27709-06 or 27709-06A.
Figure 1. Fuel Injector Part Numbers
f2447x8x
Old Style 8°
Fuel Injector
New Style 25°
Fuel Injector
NOZZLE END
IMPORTANT NOTE
In the interest of preserving customer safety and satisfaction, always check for outstanding recalls whenever any motorcycle is brought into your
dealership for either maintenance or service.
©2006 HARLEY-DAVIDSON MOTOR COMPANY
ROUTING SERVICE
MANAGER
SALES
MANAGER
PARTS
MANAGER
LEAD
TECHNICIAN
TECHNICIAN
NO.1
TECHNICIAN
NO. 2
TECHNICIAN
NO. 3
TECHNICIAN
NO. 4
RETURN
THIS TO
INITIAL HERE
M-1185 2 of 2
NOTE
Always replace both 8
affected motorcycles. Never mix 8
and 25
fuel injectors on
the same motorcycle.
NOTE
If the part numbers on the fuel injectors are rubbed off or otherwise
unreadable, count the number of orifices or holes in
the injector nozzle. The 8
angle cone spray fuel injector has
just three holes, while the 25
has six. See NOZZLE END in
Figure 1.
4. Update the ECM calibration. For those motorcycles
equipped with P&A Screamin’ Eagle 1450cc or 1550cc
Performance Kits, refer to h-dnet.com for the correct calibration
P/N.
Credit Procedure
Complete a separate warranty claim for each vehicle
serviced. Reference Service Bulletin M-1185 in the
“Comments” or “Notes” section and be sure to include the VIN
of the vehicle on which the service was performed. Fill in the
rest of the claim as follows:
Performance calibrations require pre-authorization from Technical
Service to be considered for warranty coverage unless
listed on the SWR.
Upon receipt of the properly completed claim, you will receive
the labor credit shown above.
Figure 2. Cold Start/Driveability Flow Chart
Correct condition or install
compatible components.
Are cold start or driveability
problems still evident?
Check the following:
● Fuel has the recommended octane rating and is not
contaminated.
● IAC operation.
● Spark plug condition.
● Engine is configured correctly (with the appropriate air
cleaner and exhaust).
● Vehicle configuration is supported by the correct
calibration. Refer to Calibration Information on h-dnet.com.
Does the vehicle pass inspection?
YES NO
Check fuel pressure. Is
fuel pressure between
58-62 psi?
YES NO
Replace the 8° fuel
injectors with 25°
fuel injectors.
Update ECM
calibration.
Check part numbers
stamped on fuel injectors.
Are 8° or 25° angle cone spray
fuel injectors installed?
8° 25°
Refer to SYMPTOMS
DIAGNOSTIC in
Digital Technician.
Problem
resolved.
YES NO
5388
Applicable DT Code
Refer to SYMPTOMS
DIAGNOSTIC in
Digital Technician.
Applicable DT Code
ENTRY FIELD ENTER
Claim Type PRD, MC
Problem Part No. 27625-06
Detail Part No. 27709-06 or 27709-06A
Quantity of Detail Part No. 2
Description 25
Angle
Cone
Spray
Fuel Injectors
Labor Code 5388
Time 1.10 Hours
Customer Concern Code 9203
Condition Code 5388
SERVICE BULLETIN
BIG TWINS
Purpose
angle cone spray
of 25
where use of the 8
NOTE
of the 25
Figure 1.
of 8
Manual. Install 25
f2447x8x
Old Style 8°
Fuel Injector
New Style 25°
Fuel Injector
NOZZLE END
IMPORTANT NOTE
ROUTING SERVICE
MANAGER
SALES
MANAGER
PARTS
MANAGER
LEAD
TECHNICIAN
TECHNICIAN
NO.1
TECHNICIAN
NO. 2
TECHNICIAN
NO. 3
TECHNICIAN
NO. 4
RETURN
THIS TO
INITIAL HERE
M-1185 2 of 2
NOTE
and 25
fuel injectors on
NOTE
Figure 1.
P/N.
Credit Procedure
listed on the SWR.
contaminated.
● IAC operation.
YES NO
58-62 psi?
YES NO
Replace the 8° fuel
injectors with 25°
fuel injectors.
Update ECM
calibration.
Check part numbers
8° 25°
Refer to SYMPTOMS
DIAGNOSTIC in
Digital Technician.
Problem
resolved.
YES NO
5388
Applicable DT Code
Refer to SYMPTOMS
DIAGNOSTIC in
Digital Technician.
Applicable DT Code
ENTRY FIELD ENTER
Claim Type PRD, MC
Description 25
Angle
Cone
Spray
Fuel Injectors
Labor Code 5388
Time 1.10 Hours
Condition Code 5388
Ok so I have called 2 Dealer's near me and both are saying my bike will not be covered by this and I will have to pay. WTF! lol just my luck, well one of the dealer's was a bit more involved to know more and will give me a call back later this morning, they are going to call customer service and see if they can cover this under warranty. I hope so, I don't want to shell out 91 bucks for each iinjector
Hmmm, so after swapping out the injectors which I know shouldn't take more than 30min, you didn't have to recal. the ecu at all? I have a forcewinder intake and big radius 2 in 2 and I know the tune is right on, just get surging. Well I'll have to hit up ebay if the dealer can't do anything for me.
Well Called both dealers again, they are not going to be able to help me at all, and I also called Harley Davidson and they said they were unable to help me as well. Talk about a company that wont stand behinds it's products. They wont even reduce the price of the injectors for me. WTF shitty day.
I had mine changed back in 07, I had surging, stalling, and cold start problems. The new injectors solved all of the problems.
Not all 06 models came with 8 degree injectors, make sure you do not already have 25 degree injectors.
If you do replace the 8 degree injectors, the ecm has to be re-calibrated for them. I do not know what is changed, but it has to be done.
If you have a fuel management device, SERT or PC, you may be able to make the changes without having the ecm changed by the dealer. If so and you do not have a fuel management device, I think I would spend the money on one, versus spending it on a stock ecm cartridge. In that case I would call fuelmoto and ask them for advice.
What was thier reason for not covering the problem under the bulletin?
