Part Number Request
its the white connector that when you are internally wiring your handlebars the housing that holds all 8 pins on your left side...its white and stored up underneath your gas tank, i think it controls your horn, bright lights, left blinker. i'm not sure what else you want
also, if you have a wiring diagram that shows where each wire goes ( i wrote it down when i took each wire out, but everytime i turn the key i blow a fuse.) so i need to know where i wrote something down wrong at...like i said, i'm still waiting on my service manual to get here
thanks slot
thanks slot
There is not a lot of description in the parts book, but that helps a bit. The wiring diagram shows a couple of sockets that may be what you need. This shows one each for the left and right side- #72168-07.
The other, also a socket/terminal for both sides, is #72272-07.
Both are for the hand controls, they may be the male and female connectors.
Sorry to make this harder than it should be, but if these aren't right we'll keep trying.
