Do 2 to 1 pipes perform better than 2 to 2?
New to the forum and bought a 2010 Fat Bob. I plan on buying the V&H Big Radius and am torn between the 2 to 1 and 2 to 2. If the performance is better on the one I will go that route, otherwise I will stick with the 2 to 2 since it is a bit cheaper. I didn't see a post asking this question so please let me know if I overlooked it. Thanks.
HD bike exhaust systems are so short that they are all bad systems. The difference between the 2-2 and 2-1 V&H may not be all that noticeable by the seat of your pants. You may want to go with the one you feel better about riding, unless you race a bit.
On the street, a decent 2 into 1will perform better than a 2 into 2. a 2-1 will provide more low rpm torque while 2-2 more high rpm horsepower. So if you want to show off your dyno HP numbers at the corner bar, go with the 2-2. The 2-1 will give you a more satisfying street ride.
I think there may be better performing 2-1 exhaust systems than the V&H, LR comes to mind, perhaps thunder header.
