Necessary Mods w/ new eshaust
With just the exhaust, you can use the Nightrider XiED's to help the AFR.... http://www.nightrider.com/parts/
I use them and they removed all the surging from the O2 sensors switching on and off and cooled the bike off 30 degrees since they enrichen the bike.
If you have a late model O2 sensor bike, tuning the EFI (or adjusting it) is only necessary if you don't like the minor driveability difference or you don't like the decel pop. Your bike may not run as well (if you can even notice it), but it certainly won't hurt anything, so is it necessary... no. Lots of guys are running that way without issue.
In fact, it will sound so good that your seat of the pants impression may be loads more power... but you don't have more power unless you also tune the EFI.
Start toying with the air filter, then the divability impact is more noticeable but it still probably won't hurt anything. But if your investing in a AF for performance, it makes sense to also retune to get the most out of it.
Every bike reacts differently. Some folks swear you don't need a tuner if you change the air cleaner only but I don't necessarily agree with that. I, personally, don't see the need for a tuner if all you're doing is just a reasonable exhaust mod.
I put slip-ons on mine and (so far) it seems to be doing just fine. Time will tell.
The only thing that's measuring anything after the combustion chamber is the O2 sensors. Somebody needs to explain to me why and how a reasonable exhaust system can affect the O2 sensors. All they do is read the amount of unburnt oxygen present in the exhaust. They're just reading the amount of oxygen present in the exhaust evacuated from the combustion chamber in order to keep it at stocih so the catalytic converter can do its thing. Neither of us has cats, so we don't care. The computer doesn't know we don't have cats and also doesn't care. But it's not an especialy bright computer either. Which is good for us. Sort of.
Now, if you change the air cleaner AND the exhaust, then that's a whole new ball game. Everything goes out the window.
Notice I said 'reasonable' exhaust changes. That's a cop-out on my part. Technically, exhaust can (in theory) change what's happening on the intake side of things. That's why I said to 'see what happens'.
Ride it.
If he is not replacing the AC (adding more air flow), there is no reason to spend the money on tuning it, I seriously doubt there would be any noticeable gain from the expense.
