Dyna Rear Fender Interchangeability
For those doing any mods to a rear fender that will require painting, this is a mod you should consider.
https://www.hdforums.com/forum/dyna-...seat-nuts.html
Now that I have had it for several months I can say it has been a huge benefit especially for someone like me that changes between 2up and solo seats. I tapped them for 5/16x18 threads and use these bolts for a clean look.
![Dyna Rear Fender Interchangeability-ds391357.jpg](https://www.hdforums.com/forum/attachments/dyna-glide-models/127444d1472853519t-dyna-rear-fender-interchangeability-ds391357.jpg)
To make the wiring work, you just need the '09 harness. Once you get the plug that goes into the back of the tail light, you can dyke the wires and solder everything. My bike is a little different than your stock american harleys. Although I am american, my harley was bought over here in the UK from a UK dealer. Hence the 5HD in the VIN instead of the 1HD. My wiring is a bit different, but I can help you out if you need it. It's not that hard.
Gabrielxavila
02-19-2017 12:03 PM
Angry_Monkey
03-30-2007 10:08 PM
