2009 Dyna Factory Exhaust
You can do the standard punch out of the disc in the mufflers. Some people completely punch it out, some just drill holes of various sizes. Personally, I drilled a 1/2 hole in my discs which gives me just a little more sound but would still pass a "nightstick" test.
Basically, just pull your muffler and look down it. You'll see a disc in the middle. You'll need a 12" bit or a standard bit and a 6" bit extension. I use a socket extension and a center punch to mark a center point. If you're using a bit extension, you can do the standard pilot hole/step up to target diameter.
Be sure to have someone hold the muffler tightly. I don't recommend using a vice because you can crush the sidewall. I do recommend that your holder use a rubber strap wrench. It will make the holding easier.
Oh, you won't require any fuel/engine adjustments for just pipe changes.
