Exhaust Wrap on '09 Street Bob Pipes
Well I really wasnt going for perfection when I wrapped the pipes. It's not supposed to be pretty but the spacing is mostly uniform...can't really tell with the wrap painted though. And wrapping the clamps would be far more trouble than the end result would be worth IMO. Again not supposed to be pretty.
Guest
Posts: n/a
I can't speak for the OP, but there are several valid reasons to do this. First, it lowers the temperatures of the engine, transmission, rider, and passenger. Second, it weighs less than the heat shields. Third, it quiets the exhaust somewhat, and reduces exhaust rattle. Fourth, it increases exhaust velocity, thus scavenging better and improving volumetric efficiency, which in turn helps the engine perform better. Finally, it looks cool.
Ok, I have to ask a stupid question: heat shields are what exactly? They cover up the exhaust I take it?
So removing them and applying heat wrap is much better, for the reasons tekdiver explained. Am I right?
This sounds like an inexpensive way to keep your legs from burning up. I might just do this!
