help with taking off my V&H pipes
I had this up on the exhaust Forums.
When I got my 10 FXDC my Dealer installed the V & H Big Shots and complete stage-1 before it was delivered to my home. I had them put in the Quiet Baffles so I have no idea what they would sound like with the reg V & H baffles. I was very happy with the sound when the bike was brand new. Plenty loud with a deep tone. Fist time I rode it going slow at low rpm speeds under 20 mph they kind of had a resonating empty tin can sound but as soon as I got in to the throttle they sounded great. I now have 2931 miles on her. Over the last 3 weeks or so I notice the empty tin can sound is getting louder, or at lest lasting longer in to higher speeds. When I'm going slow in town now I don't think it sounds good at all. Every thing on my bike is tight including all Exhaust parts. I don't know if the Dealer did something wrong, could the wrapping had slid down a bit when they installed the baffles or something. I know some of you on here have the same baffles, could this odd resonating hollow sound I'm hearing be normal ? Thanks for any advice.
2 guys said I should replace the baffle wrap. So I think that's what I will do. Question, Can I get just the heat shields off or will I need to take the complete pipes off? All this just to get 1 screw out that holds the baffle in. I did a Search but couldn't find the answer...Thanks.
Thank you for the advice. I went ahead and took the pipes off, good thing I did the front gasket was pushed side ways and was blocking the exhaust by about 1/4" on one side. The wrap was not burned up but the top baffle had the wrap pushed up to one end and left about 1 1/2" with no wrap on the end at all. Al so had a large tear and a small hole in it, I definitely need to replace both of them now. I fond 2 places in Lansing that sells it but it's thicker, so I hope I can fit it in. I will give it a shot Tomorrow night.
Have you ever rechecked the flange nut torque? When new pipes are put on the nuts seem to loosen up a bit as the gasket compresses. May have loosened enough to be causing an exhaust leak. I checked mine probably 4 times before they finally remained torqued to the correct value.
Did the dealer give you the original baffles when they changed them out for the quiet ones? Possible they didn't bother to put the quiet ones in. I had the same kind of irritating sound with my original baffles that went away with the quiet setup.
Oops. We were both posting at the same time. Anyhow, don't forget to recheck the torque when you get things back together.
Regarding the baggles, the Big City Thunder baggles are the best. I run them in my V&H Straightshot slip-ons and they sound like a Harley from the 60's/70's.
When you put your exhaust pipes back on, remember to put Permatex anti-seize lubricant on the threads of the flange studs. If you don't they will gall. As someone else pointed out, you will need to check the torque on the exhaust flange bolts periodically until they stay at the correct torque.
https://www.hdforums.com/forum/6902030-post3.html
Got the new wrap on. I had to buy 1 1/4" thick but I got it to pull apart to about 3/8 thick, still thicker then the very thin V&H wrap. Sounds better in the garage. For some reason it seems to backfire a bit more and they sound louder when they do pop. I will know for sure after this weekend. We are riding the bikes up to are cabin by Mancelona Mi. Should top 500 miles this weekend. Leaving at 1:00 PM today.
I will up-date on how the new wrap worked out when I get back Sunday.
skullcrusher
10-22-2007 06:17 AM
