Rear signal relocate
As far as accessing the bolt, just use an open end wrench and be careful - if you get sloppy you can smack the wrench against the edge of the fender and chip the paint. You might also be able to get in there with a 1/4" rachet and short socket, but I prefer the open end.
I changed out my HD relo kit with the one from great bikes. pretty simple deal. Thanks for the advice on jacking up the rear.
I also switched to a smoke lens with integrated turn signals that works well. but had to change out the connectors inside. These are LEDs so hope they do not get toohot and melt lens as I had read some others do. Yes, I know I need to change the turn signals to smoke. But dealer was out so will wait til I hit the states in August.
Some pics, but not so great. Pretty much the same as above. I like how they bring the sigs closer to the plates, and look much sturdier.
Don
Don
Like Taddeoeg, I have the Great Bike Gear Turn Signal Relocation Kit For Harley Davidson on my FXD 2003. It is mounted over the lay down license plate holder from VTwin (VT No. 31-3943):
Here's how it looks on my bike:
You'll find all the kits over here: http://www.greatbikegear.com/product...s/eb-TSDNA.htm
I have the kit that comes as one piece that easy bracket makes part number TSDNALD - 01C . After waiting 2 weeks for it and then I had it on the bike for two weeks when my buddy says hey your plate and signals are really vibrating - its a FXD (LOL).
Turns out the left side cracked. Now I gotta deal with the un-wiring and uninstalling. Or maybe just try some JBL weld.
Well there's way worse things...
George
