Hand grip removal help? ( Bars installed!! Pics )
Old 08-26-2006, 12:36 PM
Naz_Man's Avatar
Naz_Man
Naz_Man is offline
Default Hand grip removal help? ( Bars installed!! Pics )
Got some new bars and I need to remove the grip on the left side I think it's glued. Anybody got any tricks or no of a good way to get it off without screwing it up?
Thanks much, Donnie
Old 08-26-2006, 01:49 PM
Shrug's Avatar
Shrug
Shrug is offline
Default RE: Hand grip removal help?
I removed the grips on my dirt bikes using a blow dryer on its hottest setting. If it's not an acrolyte (superglue) type glue, that should help.
Good luck!
Old 08-26-2006, 03:15 PM
DGlide04's Avatar
DGlide04
DGlide04 is offline
Unless you want/need to save the old grip, you can take a razor and carefully cut it off the bars. If saving it is important, try spraying some WD-40 down between the grip and the bar after prying the grip up with a small screwedriver. The WD-40 should soften the glue enough to allow removal of the grip.
The hair dryer trick works, or better, if you have a heat gun, use that on the lowest setting.
Old 08-26-2006, 03:23 PM
Angry_Inch's Avatar
Angry_Inch
Angry_Inch is offline
Get a grinder. Works everytime!
Old 08-26-2006, 04:02 PM
Naz_Man's Avatar
Naz_Man
Naz_Man is offline
ORIGINAL: Angry_Inch
Get a grinder. Works every time!
Yeah that's what I wanna do.... Grind away at your bike but not mine! How Lame!!!
Old 08-26-2006, 05:00 PM
blackend's Avatar
blackend
blackend is offline
I am going to need to do this soon so I have been thinking about it, I am going to try taking off the switch housing and sliding a thin strip of metal between the grip and bars
in various spots intell it is loose enough too twist off! what do you think?
Old 08-26-2006, 07:31 PM
Naz_Man's Avatar
Naz_Man
Naz_Man is offline
I'll tell you tomorrow how it goes.... going to try putting the bars on. Just got back from the HD shop and got me a diamondback braided brake line so I think I'm ready to go........ DANG IT, I forgot the dot 5.... back to HD again tomorrow morning [:@]
Donnie
Old 08-26-2006, 10:04 PM
voyager1's Avatar
voyager1
voyager1 is offline
lmao here, no grinders donnie for sure ,ouch . i usually cut them off.
ORIGINAL: Naz_Man
Old 08-26-2006, 10:48 PM
Naz_Man's Avatar
Naz_Man
Naz_Man is offline
Were not talking about the stock grips here, I paid over 50 bucks for THESE GRIPS So I don't want to screw them up I want to reuse them.
So I guess I'll just wd-40 them and twist and turn till I get them off.
Thanks guys for you input! Donnie
Old 08-26-2006, 11:26 PM
soup48's Avatar
soup48
soup48 is offline
I changed my grips, by removing the switch housing and grabbing the hand grip and twist it. I was suprised that it came off that easily.
Quick Reply: Hand grip removal help? ( Bars installed!! Pics )
