Is this everything I need to replace the IPB
Parts Eater-
You can get away with reusing the primary gasket (as long as you dont kink it), and the starter O-ring. The 5 magic screws can be reused once, but I wouldnt try twice. You can snot the post gasket if you feel you need to. The inner primary gasket is a one-time crush gasket, so you ought to replace that one.
Patrick-
I havent seen a failure on a Baker I've installed yet. The part that scares me about it is if it does, the inner race is gonna get hot, and possibly sieze to the input shaft of the trans. I'm not looking forward to doing that job cause its gonna be expensive!
Also, the "good-will" fix from HD isnt a be-all-end-all for the problem. The newer indexed cases are having bearing failures, just not as often (and more random) as the non-indexed 06 ones are. I'm getting ready to put a third into an 08 right now (my bike). I'll continue to use the original bearing and race until the stock on the shelf is gone. Then I'll put a Baker in mine (or retire the bike).
Patrick-
yup
I kinda had that feeling about the new doweled cases not truly being a fix for anything. I really feel that the problem is the crappy style of bearing that is being used by HD and not an alignment issue. I have 16k on my 06 and the bearing looks good and so does the race.
I am concerned about the Baker unit eliminating the press fit tranny shaft sleeve. I guess I am gonna use the Baker bearing with a 15k service rotation. At leats with the Baker I dont need special tools to remove and install that inner race.
Thank You for the heads up on the reusing of certain gaskets.
Do you have a mileage report from the installed Baker Bearings??
Oh, and it isnt the bearing that causes the problem. If you ever saw the crappy machining used on the inner race, you'd understand why they fail. The first time I replaced one, the only thing that came to mind was "Guaranteed Failure". I'd swear they ran out of cutting oil when they ground the face
I owe you a beer...
It looks like I can bump up that schedule to 30k rotations. If you are ever at the beach in NC , I owe you a beer. Thank You
Bearing kit ordered
danzio
06-01-2014 04:02 PM
