bike wobbles on high speed turns?
I installed a burly 2" drop kit on my 98 wide glide. it runs straight and has no wobble during normal driving and on turns at 65 or under I do not notice any wobble, but when turning at higher speeds I get a lot of wobble not sure if it is front or back as whole bike feels it. drives good at high speeds going straight. I checked all nuts/bolts all seem good also checked spokes found several in rear loose i tightened those(while on bike) front was good.
thinking it is from rear needing tightened and trued but thought I would check here also not sure if drop kit would cause this as I did not notice wobble before drop install. have had bike for almost 3 months and lowered it after 3 weeks of ownership. thanks for all.
So you have had it lowered for about 2 months, how long after you lowered it did you notice the wobble? Did you lower the rear as well? It could be many things, but you definitely want to start with the last thing you did before you noticed the problem.
How much sag on the rear? How much travel do you have left on the rear shocks, are you riding on the stops? I would start with increasing the preload on the rear just to see if there is any improvement. I have experienced more wallow when the rear shocks are set with less preload.
How is the front fork action, soft or stiff? Is the Burley Fork kit a drop in kit? If so, this could be your problem as you have no real control on preload and I would move to a kit that uses lowering springs under the damper tube so you can actually set a proper preload. You could also try a heavier fork oil with the drop ins. If they do use the damper springs under the damper, again how is the fork action, lots of brake dive or Stiff? Check your sag, approx. 25mm, and adjust it with the proper spacer and preload and see if that improves the wobble.
CB
X parts-changing
1)after tightening spokes it did seem to help,but did not go away.
2)shocks are set at same preload-5, I am 220 and ride with my wife(120) at times.
3)looking into fork brace, was looking at RSD fender bracket as was going to remove front fender(have not removed yet).will I still need to run a brace if I get the RSD bracket?
4) I installed springs/spacers myself following the supplied directions and researching on net. it is burley brand parts, front springs/spacers and rear 10.5 shocks=total 2" drop.
figured that lowering would change handling some plus I know rack is more on the wide glide but not sure how that would all equal out.
5)followed service book for axle install but will double check that.
I am planing to have front and rear wheels trued this winter if I can
wait that long, as long as I plan the corners and watch my speed. hopefully will let me wait. figured I would do tire replacement at same time.
also have seen true track mentioned on here a few times but still not sure what and where it goes. I will check in on that.
thanks all...
thanks all...
We can always find excuses to justify buying new bike stuff, especially if there is money to burn--a fool and his money are soon parted. And parts-changers might eventually happen upon a solution to a specific problem. But are you convinced that what you have done so far is 100% aligned/adjusted, chassis/suspension/steering? I am not.
I believe you have done a lot, so far, but have given up before finishing what you have started. Subtle differences in setup/alignment, chassis tuning could make or break your handling/wobble. Before introducing yet more changes, check all alignment/adjustments!
Don't wait until next winter to find out that wheels are out of true! You can check this yourself using a sharpie with each wheel just off the ground; check bearing play at that time, and if you have tens of thousands of miles on them, replace them.; check steering head adjustments.
Only once you have done these things should you consider adding/making additional changes.
It sounds like your drop kit has amplified the inherent Dyna high speed lateral wobble.
There are so many things that can affect this; from your new rear "almost-strut" shocks to worn bushings in the rear fork, to a rear hub whose spoke holes are now egg-shaped from loose spokes, to tired - old motor mounts, to soft springs in the forks to steering head bearings giving up the ghost....it's really hard to diagnose what the problem is but................... I'll 'steer' you in a couple of directions to get you started:
Jack the bike up and put a crowsfoot or crowbar between the swingarm and the frame and give it a bump. Did it move? Did it move a little bit and in a uniform direction? Was it tight?
While you've got it on the jack just look at the rear hub and see if you can discern any subtle differences in the holes the spokes are going through.
While it's still on the jack crawl under it and 'look' at the motor mount. Does the rubber 'look' like it should? do you see a crack or any sign of deterioration?
What about your front end? With the bike back on the ground is that thing solid and smooth on compression or does it feel like it's low on oil or the springs struggling to rebound?
I'll check in 2morrow evening and see how you're doing.
wheel true
With the wheel off the ground, and a pencil or sharpie stabilized by a block of wood...and held at a fixed position, slowly spin the tire with the point just touching the center of the tire; any side-to-side run-out will cause the line to be off-center of the tread pattern; this should be clearly visible as you spin the tire. Or, while spinning the tire, hold the sharpie/block just barely away from the side of the rim so that it touches only where there is a "high" spot. Either way, you can see if it is true; if the gap remains constant, the wheel is true. Also this is a good time to check the bearings.
Same Issue here, for years actually.( constantly checking all the above advice for a solution)..have a 99 Dyna and did lower it with 11" Progressives and drop in front springs....sits even but totally amplified the issue ALL dyna's ( those that have been lowered anyway) share in the rear.....if you a bigger guy ( which i am not) you will help weigh this down and it is less noticeable ...if your under 200lbs then altering the geometry really messes you up in the curves.....TRUE Track seems to be the move i will make here....but if that doesn't do it......>i'm going back to stock lengths in the suspension!....if that doesnt work....i'm going back to a sportster!
