how much left in the tank after the light comes on?
Old 06-19-2010 | 12:01 AM
HDRusty's Avatar
HDRusty
Default how much left in the tank after the light comes on?
I did a quick search and did not find anything, so how about it... How much fuel is left in the tank after the reserve light comes on? (2010 WG)
And how accurate is the "miles until empty" reading on the display?
Old 06-19-2010 | 12:35 AM
HDDyna2006's Avatar
HDDyna2006
Someone here mentioned had about 1 gal left, just fill it up when light comes up, 06 FXDI tank takes 4.8 gal to the rim.
Old 06-19-2010 | 05:43 AM
==ShaDoW=='s Avatar
==ShaDoW==
the way i heard it it varies, me i am a bit of a rev head so i use a lot of fuel, my bike takes this into account (average on each tank) and adjust what it thinks i can do.
So what happens is when i go for a long run and I am just cruising with the pack i get better fuel mileage and hence it will say i can go further on the same amount of fuel.
funny really but once i understood that i am happy if its a long way between fuels ups I just take it easy.
Old 06-19-2010 | 07:53 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
My Wide had about a gallon when the light came on. After my tank lift, the light comes on sooner.
Old 06-19-2010 | 08:09 AM
Wonkaboy's Avatar
Wonkaboy
Last week i figured it out while riding in the city and highway that day i got an average of 57 miles to the gallon , whenever i see the light come on i try to get to the first gas station because i hate looking at the light ...
Old 06-19-2010 | 10:08 AM
SC-Longhair's Avatar
SC-Longhair
I'm very curious...how do you see that option? My '07 doesn't have that.
Old 06-19-2010 | 10:20 AM
Max10's Avatar
Max10
Last time I filled up the range said 13mi. left. Only could get about 4 gal. in on a 5 gal. tank. Doesn't look like they're that accurate but at least it's an error on the side of more gas than not enough.
Old 06-19-2010 | 10:52 AM
CRZYLGZZ's Avatar
CRZYLGZZ
im right up there as well. depending on how your bike is running, and how you run it..
id say about 1/4 gallon is about right...
i wouldnt risk running around guessing you have about 12 mtz on your ride tho...
im not a fan of MOCO mathamatics.
Old 06-19-2010 | 11:21 AM
powerlab's Avatar
powerlab
Default button
mines a 09 and ya just push the button on the speedo and it brings ya to odometer..trip and miles to empty.
Old 06-19-2010 | 11:23 AM
GymRat523's Avatar
GymRat523
I have had mine down to 6 miles to empty and the 5 gallon tank took 4.4 gal. It seems pretty close, miles to empty does adjust as you are riding, it can actually go up. On long staight roads I have seen it go up. I think I have read it come on at .8 gallons.
Quick Reply: how much left in the tank after the light comes on?
