98 fxdl - real rough at 2k
Old 06-17-2010 | 08:09 PM
tincup64's Avatar
tincup64
Default 98 fxdl - real rough at 2k
at idle - bike runs and vibrates the way i expect. right around 2k it is really really rough and them it smooths right out. entire bike vibrates dramatically right around 2k whether in neutral or riding - it feels very normal under and over that rpm range.
is this ok?
thx - tin
Old 06-17-2010 | 08:22 PM
sm0kediver's Avatar
sm0kediver
Disclaimer: I'm not a mechanic and I'm possibly your worst source for mechanical advice***
I recently had a vibration problem, and it was loose motor mounts. It couldn't hurt to check and see if they need tightening, or possibly even shimmed.
Old 06-17-2010 | 08:40 PM
tincup64's Avatar
tincup64
thx smoke. aleady replced the front one. it helped significatly at idle. this is a much more substantial low end type vibtration.
Old 06-18-2010 | 05:16 PM
sm0kediver's Avatar
sm0kediver
Still makes me think mounts. Is it vibration or running rough?
Old 06-20-2010 | 08:58 PM
tincup64's Avatar
tincup64
vibration. only around that rpm. feels real deep, like crankshaft. probably normal, took it out today for a few hours and it really runs great. its just this little nuance.
Old 06-20-2010 | 09:55 PM
rounder's Avatar
rounder
How is the carb tuned... I had this problem and I fixed it. Is your vacuum hole drilled out in the slide? what has been done to the carb?
Rattlehead73
09-20-2020 10:25 AM
gonpce
10-17-2012 01:59 PM
Anthony8858
06-14-2009 07:34 AM
TwiggyAZ
08-01-2008 11:10 AM
cravenc
08-22-2007 02:46 PM
Quick Reply: 98 fxdl - real rough at 2k
