Starter prob
Old 06-29-2010, 10:21 AM
Derv's Avatar
Derv
Derv is offline
Right guys - thanks for all your suggestions.
Bike is now sorted and and starting ok again, the problem was as I suspected the starter relay. For reference in case anybody else has a similar thing happen - all the symptoms are in my first post - the part number of the relay is: 31522-00C. It's the little grey plug in relay situated behind the fuse block mounting plate on the L/H side below the seat.
I had metered it out and it was showing ok, but I noticed when trying to start the bike that the clicking sound was coming from the relay and not the solenoid which suggested to me that the relay itself was actually faulty. Although it tested out ok on the bench it was collapsing under load in-situ. New Relay now fitted and it's all back to normal again. Just thought I'd post the info up to save anybody going "all around the houses" to fix a simple problem. As I always say - try the easy stuff first
Derv
Old 06-29-2010, 12:44 PM
sniper77's Avatar
sniper77
sniper77 is offline
Glad you got it figured out and back on the road!
Old 06-29-2010, 01:04 PM
clicker01's Avatar
clicker01
clicker01 is offline
Derv
Awesome Drev! Thanks for the update.
WVICEMAN
EVO
11-09-2014 07:36 AM
racerx143
08-27-2013 09:08 AM
ironhead3fan
05-06-2011 09:18 AM
TexasCowGrower
09-20-2010 10:44 PM
bikerlaw
EVO
08-09-2010 12:28 AM
Quick Reply: Starter prob
