Leaking primary
Received 4,796 Likes
I had a shift shaft seal go bad many years ago. Took a while to isolate that one. Using a small mirror and flashlight look up between the inner case and trans to see a source. Just wondering, did you just change your trans fluid? If so did you put in 22-24 ozs.? If it's over full maybe it's just venting on you. Had a shop do that to me once.
