Identify Parts
Old 06-17-2010, 10:13 AM
stng_96's Avatar
stng_96
stng_96 is offline
There are actually multiple plugs on some bikes that are just chilling, because there are only two different wiring harnesses from the factory. So if you bike, as stated, is domestic, and does not have security, those are two examples of plugs that will be there, but unused.
Old 06-17-2010, 03:45 PM
Taddeoeg's Avatar
Taddeoeg
Taddeoeg is offline
Originally Posted by HDTech74
I never run anything over my seat.
I bet if you saw a bike I set up, you wouldn't even be able to
tell where the tender lead was unless I showed you.
It looks factory.
Sorry, guess I wasn't clear. You'd be very hard pressed to find my pigtail as well without tracing it from the battery. When not it use it tucks up behind the fuel line qd, completely invisible.
What goes over the seat is the line from the battery tender/wall outlet to the pigtail. That's cause the way I park the outlet is on the right side of the bike and the pigtail on the left. Added benefit is that the cord from the outlet doesn't hit the hot exhaust, although I expect that's pretty high temp insulation on those wires so not likely to melt. Still, better safe than sorry.
On the Electra Glide the pigtail's on the right since the wiring for the GPS on that bike is hardwired under the fairing.
Piecollins
Electrical/Lighting/Alarm
02-25-2019 04:03 PM
t020673
09-28-2014 10:43 PM
soft 02
01-07-2012 10:00 PM
thomasf59
06-17-2007 11:30 AM
jfanton
09-15-2006 01:04 AM
Quick Reply: Identify Parts
