Vance & Hines 2 into 1 Big Radius on Fat Bob
I like mine, a lot. You can drag the front elbow in a good turn though.
If you change your intake you will need to go to a tuner or buy an ECM add on or replacement. Most will tell you that changing exhaust alone not to worry, but might be best to change all three (intake, exhaust, ECM) at the same time if you have the patience or the cash to do so.
The thing about starting this addiction, you're already F---d, the money is as good as gone. May as well just get used to that now.
Best of luck,
t
Best of luck,
t
I have an 08 fatbob with V&H 2in1 Big Radius, SE stage I and SE race tuner. I like it but the only problem is getting the oil cap off. you can do it but it takes a little working with. very tight fit. I also had a brace to the heat shield break but they replace it under warranty so don't know if this is a common problem?
Yes it performed well, I modified the baffle and had the bike dyno tuned. It produced 75hp and 85 tq with a nice flat torque curve and no dips. It did about the same as the python 2into1 thats on my 10 WG. Both stage 1.
ozsportster
Harley Davidson Videos
01-13-2008 05:33 AM
