How does your Wide Glide handle in the twisties?
Mine seems sort of twitchy especially 2 up but I can't tell if it's the bike or me since I'm still very new to it. But I just don't recall from when I rode Harleys years ago in the mountains it being as much work as this one to get around the turns. It seems like I have to focus real hard every moment to keep it in line. Is it just my inexperience that will get better with time or is there maybe some inherent issue with the bike that I should be looking at ? Thanks.
I've added a Metzler tires, True Track, Ikon rear shocks and front springs so I get pretty decent handling. When I ride with my brother on his Sporty I'm working to keep up IF I try following his lines thru the corners. Have to set up and enter differently, likely due to the rake.
Make sure you have the shocks on the appropriate setting for you.
Tire pressure where it should be.
Swingarm and wheel bearings in good shape.
Nice bike, by the way
Just looked at the True Track web site. Interesting. Is the rubber mounted drivetrain an issue with handling?
I have 11" Progressive shocks set to the stiffest setting. It needs that for 2 up but it's a little harsh when I'm alone. I need to raise it up and want to change back to the stock length. It drags the pipes real easy. Back tire is going to need replaced soon. New stock brake pads in front and new Dunlop front tire.
Lots of things to change and only so much money to go around these days. Guess I'll just have to be patient and prioritize.
